How to make an extruded face not parallel to the starting face?
mitch_b708mitch_b708 Member Posts: 17 ✭✭
New user here (probably obvious)
I'm trying to model the body of an acoustic guitar. I drew the outline, then extruded it. To make the top non parallel to the bottom, I drew a long skinny triangle and extruded it to remove part of the solid:
Is this the best way to create this shape?
I'm still learning the basics, so any other tip are appreciated.
Mitch
