Sheet Metal Flange at angle
Hi everyone,
I'm working on a sheet metal part and seem to be stuck. Maybe one off you guys knows an easy fix or workaround.
The goal it to add a flange that extrudes at an angle. I've tried by adding extrusions that fail both when sketched on the part or the flat sheet.
Any Ideas?
Any Ideas?
https://cad.onshape.com/documents/43414c9664b4b2962814b425/w/3eebdc4393805e3dd61c2edf/e/f0f2ade0065143b0c5de4a63
thanks a lot, this does work however
is a great tool for creating custom flanges "similar to Solidworks edit flange"
Where you sketch the face of a flange in 3D space, then select a piece of sheetmetal to attach it to.
