Mate sphere tangent with chamfered seat
I'm having trouble mating the small ball in this assy with the chamfer in the seating hole. (I know I can draw it in place...) Any ideas? Thanks.
It should look like this (old proe assy I'm redrawing).
NeilCooke Moderator, Onshape Employees Posts: 5,891
Slider mate plus tangent mate?Senior Director, Technical Services, EMEA0
This is one area that Onshape needs to do a little work yet. However, if I understand your question right, I think you can get what you are after with a cylindrical mate and then a tangent mate, make sure to select an edge from your base part for the tangent mate as a face causes it to fail.
There may be other combinations that would work as well, or perhaps someone has a better idea.
https://cad.onshape.com/documents/ad093d1c7d7184965936f00d/w/678aa1e18c252afdd9be64df/e/f58f5969c61b4f4939c2ebea
