When importing a file into Onshape, is there a feature that recognizes the features
josh_mandel
Member Posts: 8 PRO
When importing a file into Onshape, is there a feature that recognizes the features so I can edit the Sketch? I am trying to edit a sheet metal part that roughly the same.
Thanks
Thanks
NeilCooke
Moderator, Onshape Employees Posts: 5,997
Hi Josh, no there is not. You can use the direct editing tools though (move face, etc.)Senior Director, Technical Services, EMEA2 -
S1mon
Member Posts: 4,121 PRO
If you are specifically importing CAD of a sheet metal model and want to manipulate it with sheet metal tools in Onshape, take a look at this workflow:
https://www.onshape.com/en/resource-center/tech-tips/tech-tip-converting-legacy-sheet-metal-in-onshape
2
