Sheetmetal...Bending over an existing bend.. Can you fold a paper airplane in onshape?
Tom_20Tom_20 Member Posts: 2
edited January 2022 in Community Support
Can a bend be bent over again resulting in 4X thickness?   Can a simple paper airplane be created as a sheetmetal part or any other way?
  • wayne_sauderwayne_sauder Member, csevp Posts: 628 PRO
    @Tom_20
    I am not sure exactly what shape you are trying to get to. The only way I know to get Onshape to do what you asking is using surfaces. If you use tangent arcs in sketching Onshape sheet metal tools will convert those as rolled surfaces. If you are trying to make multiple folds come to a point (like a lot of the paper airplanes I folded when I was a boy) and still have a flat pattern, that might be a challenge.
  • S1monS1mon Member Posts: 3,774 PRO
    If you were to make a hole where the material would be distorted at the corner, you might be able to model something that sort of makes sense in sheetmetal, but it's not really designed to model materials which stretch like paper and are very thin like paper.
    There is an online origami simulator that treats a sheet of material as infinitely thin and somewhat stretchable.
    https://origamisimulator.org
    Check out Examples/Simple Folds/Map Fold
  • bryan_lagrangebryan_lagrange Member, User Group Leader Posts: 945 ✭✭✭✭✭
    Are you looking for this type of shape. Done with surface and thicken. This is a non-sheetmeatl part. Created with surface and thicken.
    Bryan Lagrange
    Twitter: @BryanLAGdesign
  • john_mcclaryjohn_mcclary Member, Developers Posts: 4,001 PRO
    edited January 2022
    here is a version that is sheet-metal with a flat pattern for each step
    doublebend sheetmetal | Part Studio 1 (onshape.com)
    For the flat patterns you will need to make them based off the design intent, but with a few tools it can be done
