Sheetmetal...Bending over an existing bend.. Can you fold a paper airplane in onshape?
Tom_20
Member Posts: 2 ✭
Can a bend be bent over again resulting in 4X thickness? Can a simple paper airplane be created as a sheetmetal part or any other way?
I am not sure exactly what shape you are trying to get to. The only way I know to get Onshape to do what you asking is using surfaces. If you use tangent arcs in sketching Onshape sheet metal tools will convert those as rolled surfaces. If you are trying to make multiple folds come to a point (like a lot of the paper airplanes I folded when I was a boy) and still have a flat pattern, that might be a challenge.
There is an online origami simulator that treats a sheet of material as infinitely thin and somewhat stretchable.
https://origamisimulator.org
Check out Examples/Simple Folds/Map Fold
Twitter: @BryanLAGdesign
doublebend sheetmetal | Part Studio 1 (onshape.com)
For the flat patterns you will need to make them based off the design intent, but with a few tools it can be done
