How to create a circular pattern that doesn't not axis around the orgin point?
geo_thampan
Member Posts: 4 ✭
I need to create a circular pattern that follows a circle which created in a sketch. But when ever I try to create a circle pattern the selected sketch follows an axis around the orgin point. To experiment I tried this outside the sketch in parts feature, which works, but it is not helping. I need to create pattern wich has my preferred axis point. Can axis point in sketch for circular patter be selected?
mahir
Member, Developers Posts: 1,319 ✭✭✭✭✭
As you're creating the sketch pattern, just drag the center point from the origin onto the desired hole center. I would also suggest going through the free tutorials at learn.onshape.com
6
The indication is the fact all the lines are blue (which means underdefined)
Once you have everything fully constrained then all the lines turn black
