Non-printing drawing notes
 randy_young
                    Member Posts: 22 ✭✭
randy_young
                    Member Posts: 22 ✭✭
                                  in Drawings
                    Is there a way to make notes that are visible in Onshape, but do not print when exported to .pdf?   I'd like to make notes for me to remind me which field is a pre-fill in the title box, since some of my title box info is not the same name (ie: I use Title 2 and Title 3 for other fields).
Things that have no background are regular text fields in the drawing that will need to be edited manually.
Otherwise, no there is no 'non-printable layer'
But also letting you know a work around until that time.
You should create an improvement request for this if there isn't one already
Have you tried this approach ? Having notes outside the drawings ? Please look at the placement of MY SPECIAL NOTES
Principal Technical Services Engineer, Onshape
jjohnson@ptc.com
