laser joint tool
Lucas_ReasonLucas_Reason Member Posts: 3 EDU
hi I recently learn about the laser joint tool from an online tutorial. however when I try to find/use it is nowhere to be found
  • alnisalnis Member, Developers Posts: 452 EDU
    You can find the tools here:
    Laser joint FeatureScript:
    https://cad.onshape.com/documents/578830e4e4b0e65410f9c34e/v/75269c4a1a5ece98be1e2b6f/e/dfd5effddfd7f2ecce4b0246
    Auto layout FeatureScript:
    https://cad.onshape.com/documents/576e01dbe4b0cc2e7f46a55d/v/731e73ac0b7b1e4334f13106/e/887d6e2324589bfd2058c3e1
    Select the + Custom features button:
    Then click the feature name:
    Hope this helps!
  • Lucas_ReasonLucas_Reason Member Posts: 3 EDU
    thank you so much you are a life saver
  • jeff_brown304jeff_brown304 Member Posts: 24 ✭✭
    This is exactly what I was looking for.  Thanks!
  • roderick_kimballroderick_kimball Member Posts: 1
    Does this require a professional account?  I cannot find the "add custom features" button.
    @roderick_kimball custom features are available for all users. Could you make sure you are signed in to Onshape? If that still doesn't work, could you please send a screenshot of what you are seeing?
  • Mr_HubbardMr_Hubbard Member Posts: 3 EDU
    edited February 2022
    Hi @alnis
    This is a great script thanks for making it. I would like to know more about the option within the laser joint script called allowances.
    I'm having trouble getting a great fit with the boxes and I imagine this option has something to do with the amount of kerf taken out by the laser. Could you describe it in a little more detail to me?
    Hi @Mr_Hubbard
    I did not make this script---all credit goes to @lemon1324!
    As for the allowance value: that is how much the faces are offset. So, if you had a part that was made perfectly, and the allowance is 0, then you would have no gap at all. A positive allowance adds extra space, for example for wood glue. A negative allowance allows you to make the parts intersect: this lets you have a tighter fit, especially if you're using a laser cutter that takes out material. If you set it to half of your laser's kerf width, but negative, it will make up the extra material you laser would cut away. You might need to play around with this value a bit by cutting some test parts to get the fit you want. Generally the value will be negative if you're using a laser cutter, waterjet, etc. that cuts directly along DXF lines.
    Sorry for the late reply!
    Thanks for the tag, @alnis.  So the "allowance" option is really intended to adjust specific things about the fit of a joint, not for kerf compensation - I wrote a feature for doing that that offsets all faces to accommodate kerf, here: https://cad.onshape.com/documents/57df36a88f63301089e8ac78/w/d336a806a8a6f0460f7bd440/e/157268905828b0fc910e365b
    The advantage here is that the overall dimensions of your part and any holes you drilled etc are also all compensated to come out at the nominal size.
    For "typical" hobby/school grade lasers I usually get good results in 6mm wood/acrylic leaving no allowance in the laser joint and compensating 0.008" kerf and 0.001" allowance in the kerf compensation feature.
    Arul Suresh
    Thank you so much for the info @lemon1324! So sorry I forgot about the kerf compensation feature... I know you mentioned it to me previously. Your custom features are awesome :smiley:
  • kostiantyn_andriiukkostiantyn_andriiuk Member Posts: 2
    Looks awesome, but how to add it on iPad version?
  • justin_hardyjustin_hardy Member Posts: 2
    If you add it on the web it shows up on the ipad app.
  • HirezzHirezz Member Posts: 2
    Hi @lemon1324,
    I want my tabs to be slightly longer than the thickness of the board so that burnt edges can be easily cleaned by sanding the tabs flush.
    However, the Pin face offset feature doesn't always produce expected results, as you can see in document https://cad.onshape.com/documents/0af9f4b3cc178e59f5cb3c30/v/355b649f903f96648a0ed6b4/e/46c857de67462e6ad951460c
    All five sides were joined in one operation. Some sides are correct (all tabs have correct offsert), some sides are partially correct (most tabs have offset), but some sides are missing the tab offset completely.
  • tom_mackenzie319tom_mackenzie319 Member Posts: 2
    Hi,
    I am attempting to use the laser joint tool but I am getting an error that says "change version of linked document." and iot will not work. I've tried to remove and re-add from the toolbar but I get the same issue. Is there a new version of the tool? Any help would be much appreciated!
