having dificulty using the extrude cut tool
lenin_herculeslenin_hercules Member Posts: 5 ✭✭
hello
i am having a hard time using the extrude cut tool on a surface, it only goes all the way troug and when i type the number it highlights red and it does not show. i tried making a plane to the depht i needed but had the same result. the depth i need to cut off is .047, is that the readon it wont work?
  • Narayan_KNarayan_K Member Posts: 379 ✭✭✭
    Presently in Onshape we don't have option "remove" in surface.Hope it will be included in next update..
