Unable to extrude and remove a sketch through a shape that I have imported
zach_norriszach_norris Member Posts: 1
edited July 2016 in Community Support
I have recently taken on the task of editing a shape that I have downloaded and imported into this software to test OnShape out. The shape imported fine but has a numerous amount of lines on it and some 3400 surfaces. I don't understand why this is but I have a feeling it is preventing me from removing pieces of the shape. When I make my own shapes, it will extrude and remove perfectly but this imported shape... not so much. Any suggestions? Also the file is a STEP if that means anything to anyone helping out.
  • Narayan_KNarayan_K Member Posts: 379 ✭✭✭
    zach_norris,Presently in Onshape we don't have option "remove" in surface.As your exported parts are in surface so you cant remove them by extrude.You can make them solid using "Thicken" option by giving some thickness.
    Yes that remove option in surface is really important.We hope Onshape will include it in next update..
    @zach_norris , It may be non-planer face or surface where you are doing material addition by extrude operation. If that is not a case then can you make your document public and share link then we get actual scenario of your problem.
