Edit Appearance with an Imported Solidworks Document
sam_biddlesam_biddle Member Posts: 20 ✭✭
I have imported a Solidworks .zip file and I am trying to edit the appearance of some of the different parts in the part assembly.  The appearance seems to update in the appearance panel, but the parts do not show the appearance change reflected in the viewing window.  Is there something I'm doing wrong?  I'm trying to change the outer cylinder and inner cylinder in this document:  https://cad.onshape.com/documents/2f70a2701926ccb2a0e6c8ed/w/a219e97ca7882f132bdb3480/e/691077162a546f40722b7866?renderMode=0&uiState=61f9766ae6edb51115e8beac
Thank you!
