New to me, warning from Safari. "file downloaded from onshape.com "part1.stl" will damage...
Paul_99Paul_99 Member, OS Professional Posts: 29 ✭✭
I've downloaded squillions of .stl files to 3d print and never saw this warning pop up from Safari:
"file downloaded from onshape.com "part1.stl" will damage your computer.
The default option was "move to trash" I did so... but thought that was odd.
What might be goin on here?
  • S1monS1mon Member Posts: 3,745 PRO
    Sometimes MacOS thinks .STL is a certificate trust list. You can right (control-) click on a .STL file that's ok and tell MacOS to always open that file type with some program (a viewer or something).
    https://fileproinfo.com/file-type/stl=10847
  • Paul_99Paul_99 Member, OS Professional Posts: 29 ✭✭
    OH... that makes lots of sense...(it is odd that this only now happened but I'm ok with a bit of mystery) Thanks!
