feature request, text notes tab
david_lang457
Member Posts: 104 ✭✭✭
in General
yes, you can work around this by doing a drawing and making big text boxes or similar, but I was realizing that I wanted to add a bunch of notes, hyperlinks, etc to a document (house plans, listing questions, links to products, etc) and there isn't really a straightforward way to do it
adding the ability to make a tab that's a link to a google doc or similar would be a great simple step (avoiding the need to write a editor from scratch), something that integrated into onshape enough to make links to items in onshape from in the doc (parts, steps/folders in parts studios, potentially variables, etc) would be an ideal long-term thing to have
3
Alternatively, you can use the link tab extension to insert an actual Google Doc document as a tab in your Onshape document: https://appstore.onshape.com/apps/Utilities/DFE73AMQ42NPMVAEQBQVP56QGLCWJ4ALJUBEBLA=/description
The downside with this is that everyone working on your Onshape project needs to have added the link tab extension to their Onshape accounts to see the link/document. Fortunately, it's free! We use this with links to our self-hosted MediaWiki instance for more serious documentation integration with our CAD on some of the projects I work on.
While neither of these is ideal, I've found they are good enough for most use cases.
I'm not sure if there's necessarily a dedicated forum thread for each extension, but there's this one here about link tab where some people seem to be experiencing a similar issue:
https://forum.onshape.com/discussion/8897/introducing-link-tab
chadstoltzfus@premiercb.com
