If you want to bring in the solid part and make changes to it you can also "derive in" into a new part studio (simpler than creating a context or than importing a STEP). Useful tip: if you do end up using "neutral" file formats, use the ".X_T" option as it is the "native" format and is less likely to have translation errors when importing.
If you want to have access to the whole feature tree, you can make a copy of the document and move the entire part studio tab to your document (but obviously it's not linked anymore...)
Inside the part studio here there is 3 parts: Part 1, Part 2 and Part 3. What I want to do is to, for example, copy part 3 and make changes on it wihtout creating a new assembly or copying to whole document (as sometimes I just need a small part inside a 3000 part assembly or part studio). It's like a duplicate function.
The "derive in" thing seems like what I'm looking for but I can't figure out how to do it.
Note that the document you want to derive from must have a version, I would have derived in part 3 from your example document in this new test but I can't because you didn't create a version.
https://cad.onshape.com/documents/a6ff1b4d0f490132e9a3b79d/w/d12a060fcc2dcd9b0a5a993f/e/8a2474bb97bda24238a1fadd?renderMode=0&uiState=6200a65fb8640438c4298cdb
Is there any other feature that is analog to what I'm doing currently without all the hassles?
-Export part as STEP
-Import part from STEP
Derive in get you basically the same thing as export/import just with one feature, the only other requirement being that there is a version in the source document.
But it's not best practice to export STEP from a "workspace" anyway as you couldn't go back to the source of your export if you needed to...
What I'm looking for is a simple right click a part and "copy it to your workspace" functionality. or something analog to "save as" that would exist in any desktop application. Derive-in, although sounds OK, requires a version and does more than I need. I don't need to go back to the original file.
https://grabcad.com/
If you just want it as is now.
Just Copy thier whole document.
Now you own it. Do what you want.
Move the part studio to your document..
Or link the relevant parts to your document...
Whatever makes sense for you.
There is no need to destroy the feature tree by export/import
This is already discussed and I've consider this "hassle".
I don't know maybe I'm too spoiled with 40 year old CAD software that allows duplicating or copying solids. I don't need a feature tree. I don't need a reference to the original file. I need to copy "a solid" from one document to another one with possibly in less steps then export to STEP and import from STEP. As I already explained the documents I'm finding sometimes have thousands of parts inside. Copying the whole document is slow, requires the extra step of copying the part after copying the document to my workspace and also needs to be deleted from my workspace after use since it was only temporarily copied. I would much rather export and import than do this.
I consider this issue answered. Thank you.
