Using STL Files in an assembly
I do a lot of 3D-Scanning for system integration. In many of these cases, I place the scanning data as a reference in an assy. It is obvious that you can import STL File into onshape. But I can't find a way to add STL files into an assembly.
Paul_J_Premakumar Member, Onshape Employees Posts: 234
Hi,
Currently we do not support meshes in assemblies. You can vote for the public improvement request here:
https://forum.onshape.com/discussion/11068/mesh-in-assembly
1
