Feature pattern incorrect behavior in sheet metal models
frank_ring
Member Posts: 44 ✭✭
Hello,
I have noticed that pattern variables as described by Lindsays Early in their
"Tech Tip: How to Use Variables in Patterns to Vary Features".
only work for sheet metal processing if the sheet metal model is finished first.
Applying the variables creates a surface and does not behave properly.
Thanks for the attention.
Frank
These two pictures show the problem more explicitly.
Where the sheet metal model is not finished appears the error (Suface)
