Part Creation - Same part for multiple configurations
We have printed labels that are applied to both flat and curved surfaces with various radii. I've created a part with configurations for the flat-mounted and curved-mounted types using a configuration variable for the mounting surface radius. A thin rectangle sketch is used for the flat-mounted config, and a thin "arc" sketch is used for the curve-mounted, with formulas used in conjunction with the config variable to fully dimension/constrain the arc sketch. The configurations are defined so that the rectangle region is selected for the flat-mounted and the curved arc region is selected for the curve-mounted. Then, an extrude is created based on the region selected to create the label. Whether it's a flat-mounted configuration or any of the infinite curve-mounted configurations, it is still the same part/part number. Is there a way to ensure that no matter which configuration is selected, the part name, description, and part number are the same?
Also - it eliminates all the math you mentioned to create the flat pattern!
One way you can do this is by configuring the properties. Note that if the part is changing, you will need to create these same configurations for the new part. Alternatively, if you are ok with using composite parts, I prefer to use the custom feature Composite Selected by @monroe_weber_shirk so that any part automatically gets added to that composite part. You can apply whatever properties you wish to the composited part.
