Unilateral profile tolerance is broken. Displays as "?"
Hello,
Until now all of my drawings have had the unilateral tolerance displayed correctly. I'm not sure when, but now they all display as "?" mark symbols. I've deleted the notation and replaced it with no success. Is this something new/what can I do to resolve it?
Left is current. right is previous
  • PeteYodisPeteYodis Moderator, Onshape Employees Posts: 554
    edited February 2022 Answer ✓
    Yes @rinko_maeshima We have a few bugs here we are working to correct.  If you use the workspace menu to ""Print" the drawing. I don't think the issue will manifest - It's only if you use the export option on the drawing tab.
    @rinko_maeshima We have a critical bug we are working on resolving for this.  I've created a ticket for you on that.
  • rinko_maeshimarinko_maeshima Member Posts: 5
    Thank you PeteYodis ! Looking forward to a resolution
    I think it just got fixed. Appreciate your time!
    Oh I spoke too soon. It's been fixed in the workspace, but after I export the file to PDF the unilateral is still broken.
    Thanks PeteYodis, the "Print" is a good workaround. Appreciate your time! -Rinko M
    @rinko_maeshima I forgot to update this post to let everyone know we did push a fix for the issue yesterday.
  • S1monS1mon Member Posts: 3,374 PRO
    I've never used that modifier in GD&T, but I love that Onshape can push fixes like this in between release cycles. This kind of issue would take months if not years to get fixed on other CAD systems.
