Not able to snap the mate connector to the center of the slot
Hi,
I want to mate the center of the slot with a hole on another part. When I hover the mouse on the surface near the slot I see all the snapping points (as shown in the picture below). The problem is when I hover the mouse to the center point everything dissapears. If I move the mouse around the slot, I get to select every points except the center one.
Is there a trick to select the center one?
Thanks a lot!
  • maude_laforestmaude_laforest Member Posts: 2
    Thank you alnis!
  • alnisalnis Member, Developers Posts: 452 EDU
    Happy to help!
