freedom with mate connector
hervé_piponhervé_pipon Member Posts: 60 ✭✭
Hello,
Is there a way to have more freedom with circular mate connector
So that the blue part can move in all the hole created by the orange part...
https://cad.onshape.com/documents/e8d2062de0ff95f77a6b4b37/w/88f7579ccec47391700eef0d/e/5656cccfe32344f8124f1bda
  • imants_smidchensimants_smidchens Member Posts: 69 EDU
    the closest thing I can think of would be a planar with limits on motion along the X and Y axes, but this might result in jerky/not very aesthetic motion. I would recommend keeping it as just a revolute within the assembly. You could set up an assembly configuration that switches between the two depending on demonstration needs, (lmk if I should elaborate) but imo it's not strictly necessary.
