Creating polygon surfaced bottle?
matthew_padgham194
Member Posts: 4 EDU
I have a student who wishes to create a polygon surfaced bottle design.
This is well beyond my current capability!
Something like this!
Any ideas?!
Thanks
Any ideas?!
Thanks
Fantastic, thank you - I think I can see how you have created the shapes and will give this a go after copying over the custom feature.
Such quick support!!
Thanks again
If you want something faster (but with less control, and harder-to-understand features), you could try another workflow (example) using my Attractor Pattern feature, which can already populate a face with some solid bodies on a pseudo-random grid. In my case I used a cone, so I could box select the tips in Convex Polyhedron without picking anything else (since it filters for only vertices and the tip is the only vertex on a cone).
I've been curious to create a feature that creates a Delaunay triangulation, and maybe even add that to Attractor Pattern but it seems a bit above my head at the moment. Maybe @konstantin_shiriazdanov could crack it.
Thanks again
