Best practices with sharing/structuring documents?
I have a personal Standard account (call it account A) and a trial Pro account (with some other engineers at my company, call it account
. I'm experimenting with how sharing works since I haven't had that much opportunity to do it until now, and I have questions....
- There's a document owned by 'A', shared with 'B'. Why can't someone at company 'B' organize that document into a folder created at company 'B'?
- When a document is shared from 'A' to 'B', 'B' can only see the things which are created in that document. If there's an assembly which references other documents that 'A' owns, 'B' can't see them unless they're shared too. In general this seems like a good idea, but what if I want to share a document and all the other documents that are referenced by that document? How do I do that?
- What project document structures have worked and not worked well for you in the past? I'm tempted now to put most of a project in a single document, except for OTS parts or subassemblies which are shared by multiple projects/products. How is this all affected by sharing with vendors, contractors, etc?
NeilCooke Moderator, Onshape Employees Posts: 5,837
1. Because the doc is owned by A and putting it into a folder owned by B would/could try to change the doc’s permissions. This would be true even if A was a Pro account although it would be considerably easier to manage.2. Put all the docs in a folder and share the folder.3. Don’t put everything in one doc for performance reasons. Also, when sharing, a vendor would see everything in that doc.Senior Director, Technical Services, EMEA1
chadstoltzfus@premiercb.com
