Sorting Variable Name
When I created feature script that import data from CSV then add to Variable Table, the arrangement are random. How can make the arrangement the way I wanted?
Here's the script:
FeatureScript 1711;
import(path : "onshape/std/geometry.fs", version : "1711.0");
annotation { "Feature Type Name" : "CSV Configurator"}
export const importCSV = defineFeature(function(context is Context, id is Id, definition is map)
    precondition
        annotation { "Name" : "Table" }
        definition.pointData is TableData;
        var importedData = definition.pointData.csvData;
        for (var i = 0; i < 11; i += 1)
            setVariable(context, importedData[i][0], importedData[i][1]);
  • _anton_anton Member, Onshape Employees Posts: 468
    Indeed, this is a limitation that shows up when a feature writes multiple variables. Do feel free to submit an improvement request.
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,873
    sort()
