Workflow for CNC
Hello,
Is there a recommended workflow, maybe with the use of feature script to prepare files for CNC milling? (I'm already using Autolayout).
The problem I'm facing is with exporting 2D DXF files- The lines are not jointed/welded. Also Need to manually select all the geometry which gets very time consuming with many parts over multiple sheets of material.
Thank you
Thank you
Also if you can afford it, Rhino is a fantastic swiss army knife of the CAD world that has a tool for everything. There's probably some quick way to do it in Rhino.
Otherwise, I think Fusion 360 is an options but would suck since so much much will be wasted for a whole CAD system I won't be using.....
https://carveco.com/
This is very good for 2d milling and engraving.
Simple to operate and no problem's importing DXF
It's ok for very low volume but once we want to process few whole kitchens a day, the workflow from Onshape to Vcarve is becoming very time consuming. Especially because Onshape exports lines as individuals so I need to manually join them together. To do this for a lot of pieces just complicate things and takes to long.
I will look into Carveco as well.
Thank you!
This sounds very weird to me, have you tried RMB and than export DXF?
