Share a project that has multiple documents to allow editing - but not to original documents
POC
Member Posts: 26 PRO
Hi,
I have a large project that I would like to share with a 3d Party, so that they can make edits to the native Onshape parts & assemblies.. I don't want to allow them edit my parts though.
The project calls multiple documents what is the most straightforward way of sharing?
Thanks
Paul O'Connor
Thanks
Paul O'Connor
S1mon
Member Posts: 3,768 PRO
Yes, if you branch documents, they would need to confine their work to the branch. You could derive parts into new documents and share those only, but then they wouldn’t have access to the full history. You also couldn’t merge their work the same way.To some degree you’ll need to trust your 3rd party. Keep in mind that every little edit is captured in micro versions which you can revert if necessary. If you just share the documents and give them guidance, the worst that would happen is you’d need revert stuff they did by mistake.Simon Gatrall | Product Development Specialist | Open For Work
1
