3dSpline and right lines
angelo_scozzarella
Member Posts: 58 EDU
Is there a way to obtain a zig-zag line with multiple right lines not curved?
of course between different parts.
https://cad.onshape.com/help/Content/linearpattern.htm?tocpath=Part Studios|Feature Tools|_____14
@Evan_Reese ?
There's a button at the top that says "Insert" which will put the feature into an insert mode that lets you add new points between existing points. Other than that, no there's not a way without clicking the plus button. Depending on your goal there's also a chance that you might find the Ortho Lines feature more appropriate to what you're doing.
