How to construct a tin slide.
hobie_smith
Member Posts: 35 ✭✭
Hello,how do I create a sheet metal part like in the picture.
In the picture you can see a children's slide.
I would like to create a goods slide from sheet metal.
The slide with a height difference of 250mm and rotated 90 degrees.
The sides are welded to it.
How do I construct this in sheet metal?
Or Vacuumforming is also possible
Or you can create many bends. Like a staircase.
Unfortunately, I can't show you how to model it efficiently since our spiral chute's 3d model is what my boss is most protective of, since many hours have been spent refining the model to a speed and accuracy that gives us a competitive advantage when quoting/desiging/building custom geometry in seconds rather than weeks. (Onshape rocks)
https://cad.onshape.com/documents/6f6d6d247bcc29d1b7e3eae9/w/15894121377cdf3b213f874d/e/4a04836c46288cc938e7bd7c
