Projection or intersection draws and solids
A construction like this would be very easy and speed with a project geometry function. Where I have to looking for onshape?
https://learn.onshape.com/catalog?labels=["Learning Pathways"]&values=["All"]
And take a look at Linear Pattern
example:
There is no function that will do this in one step...
You could pattern the full size part, create a loft along the 4 curves as an "intersect". The only thing is that the edges will follow the shape of the loft (rather than be normal to the pattern direction).
If you need the sides to be parallel to the pattern you can pattern a surface for the base of each piece, create the loft as a surface and trim the patterned surface and then extrude all these faces at once, so a few more steps...
Solid intersect ("Intersects" configuration):
Trimmed surfaces ("Surfaces" configuration):
Note for the surface options you could also do the trim and extrude before patterning (and use the "apply per instance" in the pattern), which would save you some selection if the pattern has many instances, see "Surface2" configuration in the example:
https://cad.onshape.com/documents/b4a2db4d3bc4c30d96773c15/w/bb16ff9cf84d6fe499b5a94d/e/9f261882bf7318e29e9fb2ab
To adjust — tweak the variables or sketches
This particular sketch profile gives the sides of the eight parts curvature. Either concave or convex
https://cad.onshape.com/documents/d0de42504d4cb788c05e4ec8/w/ba8a744baa872845174beafc/e/30521fbbb462984482142a1e
https://cad.onshape.com/help/Content/sketch-tools-use.htm?Highlight=Use
Use allows you to project geometry in sketches
