"Face-face" fillet?
Other CAD systems have the concept of a face-face fillet where you chose two faces (which don't need to intersect or be solid) and it constructs a fillet between then. In some cases, you'll need to tell it which direction to try to apply the fillet because there is more than one possible solution.
Onshape has a full-round which requires a third reference, but is missing a face-face fillet.
Is there a custom FeatureScript out there which does face-face fillets?
I also did a quick search and didn't see and references or improvement requests for this.
Here's the help for the Solidworks version of what I'm looking for.
Website: ovyl.io
https://www.youtube.com/watch?v=TH2x_dxKRQA
This FS is still usefull in some cases, such as when working with sheet metal parts, where the Onshape feature doesn't work.
But it doesn't solve the face-face fillet
In this case, maybe you can use delete face and then fillet
That's an interesting FeatureScript, and useful for sheetmetal, but it would not solve the issue I was having.
If I could get delete face/heal to work, I would have done that. Where a Face-Face fillet is especially useful is when the underlying faces don't want to extend to intersect, but a large enough fillet will fill the gap or replace the faces that are in between.
