How can I get OnShape to make 'different' line selection?
john_smith077john_smith077 Member Posts: 175 ✭✭✭
Hello
When selecting lines for some operation (e.g. when I am doing some Chamfering), OnShape keeps making the wrong line.
Is there any way to get OnShape to select a different line to the one that it selects by default when you first do a mouse-over action?
I keep having the problem that I need to select a short line, that is in exactly the same place as a longer line, and I can't work out how to get OnShape to highlight the line that I want.
Thanks
J
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,933 image
    Use "Select other" in RMB menu or by pressing key above the tab key.
  • SethFSethF Member Posts: 132 ✭✭✭
    edited April 2022
    Right click and click "Select other"
    Classic.. Didn't refresh the page before answering.
  • john_smith077john_smith077 Member Posts: 175 ✭✭✭
    A bit clunky... but yes that works.  :)
    Thanks
    J
