How can I cut a fillet for a limited distance down an edge?
john_smith077john_smith077 Member Posts: 175 ✭✭✭
Hello
(Sorry, one more question!)
How can I cut a fillet (or fillets) for a limited distance down an edge?
Thanks
J
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,922 image
    Not possible directly. Easiest way would be to split the part first, then fillet one side of the split, then boolean back together.
  • john_smith077john_smith077 Member Posts: 175 ✭✭✭
    OK, got it. Thanks.
  • S1monS1mon Member Posts: 3,745 PRO
    You can also add a protrusion to act as a block, and then delete face/heal to get the desired result. Neil's method makes more sense in many cases, but the blocker method can be helpful. (It's something I learned to do with Solidworks from tutorials like this: https://dimontegroup.com/filleting-master-class/)
