Is it possible to replicate a solid that has been plastic dipped (say 1mm thick)
https://cad.onshape.com/documents/1a7f71611062f9ed9f63a8bd/w/d911a6517cde51e624d9da6e/e/edd1de9d85480994137d0085
I want to "plastic dip" this dumbell do I have to model it as surfaces and offset them?
Thanks Derek
Thanks Derek
eric_pesty Member Posts: 2,282 PRO
Select the whole part (hide others and box select), then use offset surface with 0 for the offset value, then use the "thicken" on this surface1
