Sketches From Scanned Documents
Is there a way that I can convert a scanned hand tracing into a sketch for use in a 3D model?
  • eric_pestyeric_pesty Member, pcbaevp Posts: 2,602 PRO
    Not directly...
    You can import a picture onto a sketch and trace it manually (using lines/arcs splines, etc...)
    Or what I have done before is use a tool such as inkscape and do a "Trace Bitmap" of your sketch and save to a DXF, you can then import the DXF to Onshape and use it directly
    Not directly...
