How do i make a 3 point arc go at a right angle
VzixaeVzixae Member Posts: 2 EDU
I am currently trying to make rails. I am currently stuck and I do not know any way to make the arch a perfect 90 degrees. So does anyone have any tips to help me.
  • Domenico_DiMareDomenico_DiMare Member, Onshape Employees Posts: 87
    Hi @Vzixae
     It would help if you shared an Onshape document that you are working on or pictures of what you are trying to achieve.
  • mahirmahir Member, Developers Posts: 1,314 ✭✭✭✭✭
    If you mean you want the arc to be exactly a quarter of a circle, you can just constrain the endpoints to be horizontal/vertical to the center point.
  • nicholas_radzykewycznicholas_radzykewycz Member Posts: 30 PRO
    If you need a quarter circle that is not aligned with horizontal or vertical you can use construction lines that are set to perpendicular and meet at the center point to make it 90 degrees as well. Though most cases fall into horizontal / vertical.
  • dirk_van_der_vaartdirk_van_der_vaart Member Posts: 552 ✭✭✭
    I think you need to use the Tangent command in sketch mode.
    I always think it's funny when someone posts an exceptionally vague question and everyone on the forum goes through the exercise of trying to read their mind  :D
  • steve_shubinsteve_shubin Member Posts: 1,111 ✭✭✭✭
    In very similar manner, I’ve thought of it as being kind of like one of these game shows you see on TV
    Were you try and guess what the person is trying to convey, with that OP saying as little as possible
    And like you say @mahir , a number of us just jump right in whole-hog
    It is funny
