CAM: cloud-based, linked with Onshape CAD, and with simultaneous 5 axis functionality
Cedric_Eveleigh
Member, OS Professional, csevp Posts: 72 PRO
I would like there to be cloud-based CAM that is linked with Onshape, meaning that toolpaths can be quickly updated after modifications to a CAD model in Onshape. The CAM tool that I suggest should have modern functionality, including simultaneous 5 axis toolpaths.
Although it appears to be gone from the app store, VisualCAMc almost fit the bill: it was linked with Onshape but it couldn't generate simultaneous 5 axis toolpaths (and it was expensive).
I'm currently using Fusion 360 for CAM and Onshape for CAD, and I waste time updating toolpaths in Fusion when I make modifications to the model in Onshape; this is because I need to download the 3D model from Onshape, upload it to Fusion, and then re-create the model feature selections in the CAM menus in Fusion. If Onshape CAD wasn't so good, I would've switched entirely to Fusion 360 for its linked CAD and CAM.
