Using Tangent Arc
Hi,
I'm kind of new to Onshape, and I don't use CAD for business reasons, which means I'm not an expert at all
However, I'm struggling with the tangent arc command, which is not behaving the way I've seen it in other CAD programs.
This is what I want to archive: connect a tangent arc (to a line or another arc, doesn't matter), but be able to chose the direction of the arc.
e.g. drawing a vertical line, adding a tangent arc to the endpoint, but not the way Onshape suggest to do, instead the opposite way (concave if that makes sense).
Is there an easy way to do that?
Many thanks, Wolfgang
andrew_troup Member, Mentor Posts: 1,585 ✭✭✭✭✭
Wolfgang
The tangent arc tool does work in the way you want it to: you can concatenate arcs, maintain tangency, and still reverse the direction of curvature simply by moving the mouse.
You might need to do a hard reload of the browser tab (Shift + Refresh) to dump and reload the cache: sometimes functionality is lost during a session, and this usually restores it5 -
nav Member Posts: 258 ✭✭✭✭
Hi @wolfgangh I remember trying to use the tangent arc tool earlier when I wrote my post and didn't behaved as expected, I use chrome, but opened OS in Safari and it behaved as stated by @andrew_troup, went back to chrome Reloaded the browser and now is fully working as intended, you can concatenate arcs, and change direction with the mouse, thanks @andrew_troup .
Nicolas Ariza V.
Indaer -- Aircraft Lifecycle Solutions5
Hi just keep finger on the mouse don't let go as this will finish command. Move mouse to left or right and the arc should invert to other direction. Then when happy don't forget to check menu and leave the tangent arc line!
thanks for the quick answer. Unfortunately, this is not exactly what I'm looking for. I do know how to use tangent arc in general, but what do I have to do to get the bowing in the opposite direction (sorry, I'm not a native speaker, it may not translate very well)?
If I draw a line from bottom to top, and I want to add a tangent arc from the top end of the line, I can get that to the left or the right, but always having the bow facing upwards. I do want to have a bow facing downwards (hollow?)
Hope this explains it a little better.
Thx, Wolfgang
thanks, this shows how it works with 3 point arc, and I'm able to do that as well. But what about the tangent arc (drop down the 3 point arc menu)?
In Alibre, I can chose the direction by moving the mouse. Can't get this working in Onshape (and I bet, it's a stupid user error
Thx, Wolfgang
If you look at the picture below, the previously mentioned method with 3 point arc is not really helpful. You can still sketch this with some construction lines and diameters as I've done, but using the tangent arc would allow you to concatenate tangents, set radius and angle to get the same result bit easier (if you look at the R8 tangent, than R22 (20.01 degrees) and than R15 (20.07 degrees) etc.
Pic:
But as said earlier. I'm actually treeing to understand the differences and how Onshape works. So thanks for all of your replies!
Thx, Wolfgang
thanks to @andrew_troup, @nav and @Narayan_K !
I'm now able to use the tangent arc. It was most likely not just a simple reload problem as stated in the answers above, but also a situation in my sketch. If you look at the R22 tangent starting from the R8 tangent, you notice a construction line coincident to the R8 tangent. as long as this line exists, I can't use the tangent arc in a way I'd like, but after deleting the line, I can immediately use it as demoed in the animations above.
So again, thanks to all for helping!
