Why can I not put a mate connector in the center of this face?
I'm trying to create the Siren's Soul that is from the book Ready Player Two, the sequel to Ready Player One. I created 7 "Shards" using 2 sketches, a loft, and a mirror of that loft, based on the picture of a shard on the cover of the book. I put these Shards into an assembly, but I can't place a mate connector in the center of this type of face on any of the shards.
How do I put a mate connect in the center of this face, and what spherical shape can I make with these 7 Shards to make a Siren's Soul?
I'm pretty sure the end result, if there is one, would be hollow, but I can't piece it together in my brain. Help with these 2 problems would be most appreciated!
S1mon Member Posts: 3,460 PRO
Most likely, the face is not flat. If you created it with a loft, or a ruled surface, Onshape won't treat it as a flat plane, even if it could be mathematically. If you can select the face as a sketch plane, you should be able to place a mate connector in the center. You could work around this by creating a sketch plane through 3 of the 4 corner points and then constructing a center reference to use for the mate connector.Simon Gatrall | Staff Mechanical Engineer | Carbon, Inc.
1 -
EvanReese Member, Mentor Posts: 2,516 ✭✭✭✭✭
I don't think Ernest Cline planned on you trying to model this, and I'd further venture to guess the cover artist didn't consult the authorMaybe take some creative license by starting with a sphere and cutting it into any 7 shapes you like. They're shards of a shattered soul after all (or something like that).
2 -
F14Z said:question: how to you make shapes like icosahedrons and dodecahedrons?
https://cad.onshape.com/documents/2c40f522f1b5a02f6ce9ce01/v/ee60791c01dc2c1c3f035a49/e/ff4f6157c94f693e713e91d3?jumpToIndex=740
https://cad.onshape.com/documents/d1dd5899a87b6e8d6bfa18c6/w/713231a741e44791cb393d75/e/0ada17a2d951cb11eb6663bd
https://cad.onshape.com/documents/a527281ced95c17d95452888/w/e35cf0482163129457c5312a/e/31d596afdc1bac3b0c949ee3
and the book says that the Seventh Shard is identical to the 6 other Shards, meaning they are all identical in shape but not color, and that when they were pressed together, they "snapped together like pieces of a puzzle" into a spherical-like shape. @Evan_Reese I only have my Shards like that in order to keep them together so they won't move around, thats not my final thing, thats just to keep them in the same spot until i fix the center mate thing. also, do you want me to individual share it to you? if so, can you tell me how to do that?
