Unable to edit existing fillet?
elliott_grierelliott_grier Member Posts: 3 PRO
I don't have any options to edit a fillet in the pop-out menu. I can double click on the fillet in the tree and add edges to the selection, but that doesn't show the list of existing edges. Is there a setting somewhere that got flipped?
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,927 image
    That doesn't look right - the fact that the names are grey and italic means that the feature is not regenerated. Does the Part Studio have a lot (hundreds) of features? You could try rolling the Part Studio back to the first feature and rolling forward again to see if it will regenerate or even close/open the doc. If not, please create a support ticket.
  • elliott_grierelliott_grier Member Posts: 3 PRO
    Thanks Neil. A computer reboot fixed it.
