How to connect two parts in a sketch?
VoyagerVoyager Member Posts: 19 EDU
edited May 2022 in Community Support
Hey, I would like to move those circle over to the red point, without breaking any bond/ dimension.
How can I do that?
Thanks!
  • Axel_KollmenterAxel_Kollmenter Member, pcbaevp Posts: 436 PRO
    Hi, you can either drag an drop the center of the circle to the red dot or click the centerpoint of the circle and your end of th ecunstruction line and then click the coincident connection
    Best regards,
    Axel Kollmenter
    Best regards,
    Axel Kollmenter
