Copy and paste sketch to multiples planes on a cube
My CAD class has a project where we are making a cube. How do we copy a sketch from one side of the cube and paste it onto multiples sides of the cube?
Any help is appreciated.
https://cad.onshape.com/documents/28c0bc71403af2c2cd133f35/w/531d78ade1be79fba99b4ee1/e/a8bd72ef89ebb09248469b95
Independent Onshape Consultant
https://cad.onshape.com/documents/25a0a6dfaa76e64574a5e0db/v/8217d6d96ccc324b8dd86160/e/4c62c06c4e0e4db3703a2d4c
You can actually copy a sketch (right click "copy sketch") and paste it on a new face (select face and right click "paste sketch"), but you'd have to edit it to constrain it again if you want to edit it separately after. You'd have to paste it on one face at at time but it's pretty easy to do...
Here's an example with the transform pattern patterning sketch1 on some of the faces and "sketch2" being copy pasted from "sketch1":
https://cad.onshape.com/documents/46a326b4a97bd99579866e64/w/98aff52f023b0b23139beb54/e/a699a4775463f98ce0b0d693
You can copy paste sketches as well. You'll need to transform each paste to correct position. Will not maintain geometry between sketches.
As Neil indicates, these may not be the most practical methods.
https://cad.onshape.com/documents/65753e08aca8d4b30d6b151b/w/7c9c24eefc69c7c393e4fae5/e/ba75cf0069ceb1fe4dd92fa4
Also, I was wondering why you are creating a circular sketch (sketch2) for the pattern axis when you can just use an implicit mate connector on the center of a face instead...
You could also check the "centered" checkbox on circular pattern2 to eliminate circular pattern3
