Help Me shell this part
  • steve_shubinsteve_shubin Member Posts: 1,111 ✭✭✭✭
    edited May 2022 Answer ✓
    @vishal_sharma854
    https://cad.onshape.com/documents/61b45df181f5e20cf3f97219/w/aeb882e8c326cd29046c4dcb/e/162aa1e35af6ff0aae58d9f4
    First off, before even thinking about the shell, I noticed a couple ripples or buckling in the surface of your part. And I wanted to eliminate those. I thought simplifying your initial sketch would help to remedy this
    So I altered Sketch 1 where you had that large arc on the top surface towards the front.
    I re-ordered some of the features, and in so doing, was able to eliminate one of the chamfers
    I moved the front face of that upper projection backwards just a little bit so the small fillet would work
    And I shelled before applying that small fillet
    @vishal_sharma854
    @vishal_sharma854
    You could also move that upper projection forward of the lines shown in yellow above. And the small fillet will also work if you do that
    You just cannot have that small fillet falling right on top of those yellow lines, because that’s when the fillet will fail
    Look at Part Studio 1B
  • vishal_sharma854vishal_sharma854 Member Posts: 4
    Thanks, @steve_shubin this is great, and the part looks much better, the rearranging of the features is a good insight and I'll use this in my future projects. I'm gonna try and 3d print it after adding the remaining features.
    Thanks again
    @vishal_sharma854
    it was my pleasure
    It made me happy hearing that it helped
