How to make indicator for dimensions?
I made test case with camshaft. I want to save linear distance of lifter move related to camshaft rotation degrees for full 360 degree rotation. Is this somehow easily made in onshape or should I dive in to featurescript?
Example: https://cad.onshape.com/documents/c85919f5e792e3479147e966/w/cb0ad8ba11ee8da2b3897b1f/e/f3c74d65da86cb90d7d9da0f?renderMode=0&uiState=62990f4b6164fb05c89bab1e
https://cad.onshape.com/documents/c85919f5e792e3479147e966/w/cb0ad8ba11ee8da2b3897b1f/e/f3c74d65da86cb90d7d9da0f?renderMode=0&uiState=629910576164fb05c89bab79
Then you can change the configuration in the view to the next angle and the dimensions will update accordingly.
It would be great if you could make a table where there would be automatic measurements in different configurations.
Example:
Have you noticed that Onshaped released new functionality in August 30, Driven Variables ??
I believe this is what you are asking for .. ?
I just saw that you can not show Driven variables in a configuration table. It would be nice if they can be listed there as Read Only.
Maybe you should send this as an impovement proposal to support ???
