Interference in a Hinge
paul_coyle
OS Professional Posts: 4 ✭
Is there a command in Onshape that will help me find interference in a hinge?
It's probably obvious but section view seems to be the only option I can find.
Stuart_Tod
Member Posts: 65 PRO
@paul_coyle ,
No 'simulation' support yet in Onshape, if you search the forum you'll find other discussions on the subject. Pretty sure it is in there as a previous improvement request.5 -
3dcad
Member, OS Professional, Mentor Posts: 2,476 PRO
You would need 'Limit mates' and 'Assembly Inteference check' - if you request these by sending feedback through ?-menu, you will get noticed when they get implemented. The more requests there is for certain feature the higher priority they get.
I would need these both too.
//rami7
