Named View Data? Save and use across different documents and render studio?
Is it possible to save a named view that you like in one part studio/assembly/render studio, then have the ability to use that named view in other non related documents for consistency?
Maybe a way of seeing that data and having the ability to enter the numbers for a new named/saved view in a different document?
Based on the origin, zoom, angle, rotation, pan etc? Like a saved camera position you could say?
I know it was there for sure, I used it several times...
The feedback is,
Currently it's not possible, the closest that can be done atm is using the default view cube positions.
It's a requested feature and currently being worked on.
