How do I draw/place different parts on a sphere?
ismat_jahanismat_jahan Member Posts: 25
I want to recreate the design below. What would be the best way to do it?
I haven't drawn anything over a sphere or curvy shapes before but only practices the warp feature in addition to boolean subtraction & intersection to create new parts curvy on both sides.
But I am really confused with how do I add the metal/aluminum brackets over the curvy surface from the scratch? Also how to calculate equal distance of the flower shaped parts/place them at the right place where I need, all over the sphere?
I am struggling here....Suggestions please...
  • eric_pestyeric_pesty Member Posts: 2,200 PRO
    edited June 2022
    The way I would approach it would be to create a hollow sphere on the origin (with a revolve for example) of the same thickness as the pieces on the outside.
    Then sketch the outline of the piece (say centered on the front plane) and extrude with "intersect". If you nee side faces of shape to all point towards the center it's a bit trickier, maybe in the case you would use a loft between that shape tangent on the outside and a point at the cente of the sphere (I think that should work?)
    Gave it a quick try and it looks like it would work...
    You would want to put a mate connector in there so you can place it in the assembly (and then pattern it in there).
    The metal bit can be sketched directly on one of the "arms" of the part. You would then use the same process for the other bits. I haven't looked at what the angles need to be but you get the idea...
    https://cad.onshape.com/documents/c3c71edee5eab91be153228d/w/4627d123a3cb28e4ccf99aa7/e/e2597e69bf64f02453705129?renderMode=0&uiState=629bdc800bee3252bb2aa924
  • ismat_jahanismat_jahan Member Posts: 25
    Your detailed description with the document helped me a lot to understand the idea. Thanks a lot for your time & effort! <3<3 Happy me
    @ismat_jahan
    You're welcome! Now you "just" have to figure out the math and angles to recreate the parts on the picture.
    Good luck!
