New Feature: Mate Pattern
imants_smidchens
Member Posts: 69 EDU
So I was modeling some regular polyhedra, trying to figure out how to do so in steps I could replicate on a manual milling machine (to make them out of aluminum later), and realized many of the steps were duplicates along different axes, and thought: "why spend 5 minutes doing this manually when I could spend 5 hours automating it?"
you can find the feature here:
https://cad.onshape.com/documents/9c752e0adbf4c48c7d7f03e7/w/d7e93e4064adfa2059de985c/e/840df4768729f2d4c0b339f2?renderMode=0&uiState=62a37179295a0e6ee542bf2b
and it lets you do things like this:
I haven't added this yet and gone through the flow, so maybe this would be obvious, but I'm trying to understand how this is different from other tools like Point pattern and MultiMateConnector. It seems like it's a bit of a mash-up between those two. Perhaps you could expand a bit on what problem(s) you were trying to solve?
Seems similar to transform pattern as well. Is it appreciably different that you're aware of?
Here's the corrected link (hint: if you see anything other than "cad" before onshape.com in the URL, change it to "cad")
https://cad.onshape.com/documents/25a0a6dfaa76e64574a5e0db/w/ed2afaf5bd2d12066495dc84/e/a71ff51699ae36f356a38f69
