Is map order arbitrary?
EvanReeseEvanReese Member, Mentor Posts: 2,788 PRO
When I have an empty map and I add new entries, does it add them in any particular order? If not, can I force it to? For example if I do this:
var myMap = {};
myMap.one = 1;
myMap.two = 22;
myMap.three = 333;
print(myMap);
The printed result might look like this, which is out of order. I hoped it would always add the new one at the end.
{"two" : 22, "one" : 1, "three" : 333}
  • john_mcclaryjohn_mcclary Member, Developers Posts: 4,035 PRO
    I figured the map was based off of a hash table, or dictionary in other C-like languages.
    Where each item in the map is assigned a random hash code that can be looked up quickly given the key.
    So, it's position of an object in the map is irrelevant to function and becomes unsorted.
    (103) 10. Dictionaries - YouTube
    This video will teach you everything you want to know about dictionaries, but you can skip to about 50min, that's when it gets out of the theory and into a more practical view of it.
    I'm not sure how Onshape handles the specifics, but I would assume the hash code is generated in the same way as the internal IDs in featurescript.
    Or I could be completely wrong.
  • _anton_anton Member, Onshape Employees Posts: 510 image
    https://cad.onshape.com/FsDoc/relational.html
    Iteration over FS maps should happen in key order. I expect to (and do) see
    { one : 1 , three : 333 , two : 22 }
  • EvanReeseEvanReese Member, Mentor Posts: 2,788 PRO
    Thanks, John! I'll check it out.
  • ilya_baranilya_baran Onshape Employees, Developers, HDM Posts: 1,253 image
    @john_mcclary if you want details you can have them: FeatureScript maps are internally implemented as functional AVL trees (sorted, balanced binary trees), rather than hash tables.  This is to make the following kinds of code fast and memory-efficient:
    println("Old value: " ~ x[3]);
    println("New value: " ~ y[3]);var x = { large map };
    var y = x;
    y[3] = 5;
    With a hash-table, we'd basically have to make a copy on either the second or third line, but with a tree, we can share almost the entire tree between x and y.  Plus I think that having the data in key order is nice.
    Cool, i'm going to have to learn more about avl trees to digest what you're throwing down. But that's good to know how the nuts and bolts work.
