New Feature: Mate Pattern
imants_smidchensimants_smidchens Member Posts: 65 EDU
So I was modeling some regular polyhedra, trying to figure out how to do so in steps I could replicate on a manual milling machine (to make them out of aluminum later), and realized many of the steps were duplicates along different axes, and thought: "why spend 5 minutes doing this manually when I could spend 5 hours automating it?"
you can find the feature here:
https://cad.onshape.com/documents/9c752e0adbf4c48c7d7f03e7/w/d7e93e4064adfa2059de985c/e/840df4768729f2d4c0b339f2?renderMode=0&uiState=62a37179295a0e6ee542bf2b
and it lets you do things like this:
  • S1monS1mon Member Posts: 3,445 PRO
    edited June 2022
    @imants_smidchens
    I haven't added this yet and gone through the flow, so maybe this would be obvious, but I'm trying to understand how this is different from other tools like Point pattern and MultiMateConnector. It seems like it's a bit of a mash-up between those two. Perhaps you could expand a bit on what problem(s) you were trying to solve?
  • imants_smidchensimants_smidchens Member Posts: 65 EDU
    S1mon said:
    @imants_smidchens
    Sure! The main issue I have with Point Pattern is that it always preserves the original rotation (plus requires sketch points/vertices in order to pattern to locations. This is sort of an expansion of that, with all the same base functionality, but also the option to transform using coordinate systems (either mates or determined from sketch point/sketch plane), allowing for patterned instances to have different orientations at each location.
  • EvanReeseEvanReese Member, Mentor Posts: 2,503 ✭✭✭✭✭
    Thanks for Sharing @imants_smidchens. Looks like good work as usual!
    Seems similar to transform pattern as well. Is it appreciably different that you're aware of?
    unfortunately i don't have permissions to view that document, but you are most likely right and this is a duplicate of that!
    It's frustrating how Onshape Enterprise accounts make sharing FeatureScript links complicated.
    Here's the corrected link (hint: if you see anything other than "cad" before onshape.com in the URL, change it to "cad")
    https://cad.onshape.com/documents/25a0a6dfaa76e64574a5e0db/w/ed2afaf5bd2d12066495dc84/e/a71ff51699ae36f356a38f69
    It really really is.
