When "Named Views" dialog is open, measurements disappear
scott_fallscott_fall Member Posts: 5 PRO
When the "Named Views" dialog is open, measurements which are usually shown in the bottom right corner disappear.
You do not have to actually select a named view for this to happen, it is not related to taking a section view, etc.
Pressing the "M" button for detailed measurement does nothing when the "named views" dialog is open.
Closing the named views dialog brings measurements back in the lower right corner.
This seems like a bug, but annoying when you use named views frequently and like to have that dialog open.
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,886
    Good catch - please create a support ticket so we can get it fixed - thanks.
  • PeteYodisPeteYodis Moderator, Onshape Employees Posts: 556
    Support ticket already created  ;)
